Bryan Williams
- Manchester England
Still getting slag trapped in inside t joints when arc welding today I was using a little Clark arctig 90,then swapped over to a Sealey 180, which was a bit hotter (I couldn't tell the setting) and the weld was better but still had slag in it
I was welding 5mm plate, using bohler rods.
I was given the rods by work as the lads didn't like them.
Frustrating, I have the angle of the rod ok, I tried tilting the job up and laying it flat, I had the rod just off the steel about the thickness of the rod, I was moving so I could see the weld pool I could hear when the slag was just about to fall forward so sped up a bit but still not getting a smooth slag free run.
