The Coal Man
- Surrey, UK
Hi,
Would anyone please be able to assist in identifying a bearing type?
It is a 4 bolt flange bearing housing but I am not sure what the correct name is for the insert. I need to get a replacement housing and insert but after searching online I cant find a correct match.
The dimensions are listed below.
Housing is 50mm square (chamfered corners).
The TDC between the mounting holes along each edge is 35mm.
The bearing bore is 12.45mm.
The bearing insert only has rotation about its vertical bore axis, there is no sideways movement. Also, there are no grub screws in the collar to tighten onto a bolt/shaft. I have attached a couple of pictures below.
Thx
Thx
