mrsbruce
- Livingston, Scotland
(Apologies in advance if in wrong section).
I have a small project if anyone has the time or inklingto take it on.
I need a heavier mallet for my leatherwork, but it also needs to be small. I have this cheap Chinese mallet (picture 2), and am happy to use the handle and poly hitting surface, but would like to increase the thickness, and so the weight, of the screw top and bottom washer to something similar to the first picture.
Would someone out there be willing to fabricate the parts needed, please. I know I could cobble something together with steel washers, but this is my little treat to myself, so willing to pay for something that looks and feels good to use.
The threaded rod seems to be 10mm, and the top is 8mm thick, and I would like it to be 16mm thick. The bottom washer would need be about 10mm thick.
Forgot to add, handle id 12cm long, and poly is 5.7cm.
I would need a longer rod for it all to fit together. As you can see from my bigger maul, they used a locknut at the top, but the second one is (I assume) a threaded end cap, which I like.
