Evening all. Bit of a stab in the dark here but hoping you guys can help
Been building a drift trike over the last few months, the axle is made up of a length of steel bar turned to 27mm to slide through 2 bearing carriers. Have a sprocket and brake disc carrier welded to it.
Had a friend turn it down and cut the key way as I had no access to a lathe at the time. Fitted it all up and went for the first test ride today and it appears the axle doesn't run true, giving a feeling the wheels are oval!
Easy option is to start again with the axle but it's more time and money.
Any suggestions? Current thought is to turn it from the bearing to the end down to say 20mm and then make up a new sleeve to sit inside the bearing, hoping it will then run true
