“It is after all the strongest weld for thickish sections”
The weld metal is no stronger than that deposited with GMAW or GTAW.
That’s down to poor quality consumable or welder skill.
A 80ksi wire is the same strength as an 80ksi rod at the end of the day.
Exactly its how the weld is deposited. Most of the time the weld metal will intentionally be stronger than the parent metal as we already knowNo question. But the issue is the penetration surely?
granted ! but mig is very suspect on lack of fusion . horizontal buttwelds in particular
ive seen it lots of dig outs that had to be stick repaired
It’s only my opinion but this may only be the case with downhand in certain cases, Now GSFCAW is a different animal altogether...You get more penetration with GMAW than SMAW.
Thawing pipes? Although, I'd think most rural supplies wouldn't be in steel / iron / copper conductive pipes nowadays. There might be a couple of properties on his route where it could be useful, though.The bloke who reads our water meter also has a small stick set in the back of the van. Keep meaning to ask what he uses it for but forget every time.
It was 86-87 that the switch occurred in my case I remember the boc guy Comming in (the firm where also agents for boc) the gaffer asked me to put it on my machine to test it.. By the end of the day everyone had a do and loved it argoshield 5 I think.. We switched straight over on every machineThats true especially Side wall LOF when using CO2...back in the 70s most MIG was CO2....it was sometime later when Ar rich started. I remember the Reps going round demo-ing a new wire that welded better...in fact it was the gas....I think that would be mid 80s....even then MIG was classed as semi-skilled welding which is why Im sceptical about MIG being used in 1976 on the Kielland....it was built in France but to American specs........for a long while there was no AWS for MIG wire....Lincoln called it small diameter Sub Arc Wire as they wouldnt make anything unless it had an AWS standard......but I dont know the date of the first AWS A5.18....
In the wrong hands yes, but with the correct torch angle (on pipelines if you trust your mate on the other side get them to drag the top quarter up for you ), speed up a little and keep your wire at the edge of the pool you’ll have no troubles!Yes I’m speaking of downhand.
GSFCAW is often lacking penetration in the 2F position. Particularly all positional wires.
GSFCAW tried and tested on 1000’s of manual welds on Subsea Pipelines, even on SCR’s, a robot (or bug on a pipeline) is only as good as the person that’s programmed itEven when doing everything right I’ve had lack of fusion. Set up on a robot so consistent travel speed and stick out.
...keep your wire at the edge of the pool you’ll have no troubles!
