Hi all, looking at getting my first MIG welder (likely the seemingly infamous Clarke 151 EN, or something slightly more powerful). I may also get a stick or TIG welder at some point in the future if that influences any answers.
I plan on welding up to 5/6mm bar/plate/tubing, and one-off thicker pieces for furniture that won't need to have too strong welds (e.g. 12mm thick I-beam flanges).
With this in mind (and as we're already doing building work), I'm going to get a line run from my consumer unit, so:
1. Will a 16A dedicated supply be sufficient, or would 32A be future-proofing or too much?
The only suitable welding area is ~20m away at the end of the garden, so I was planning on having a round 3pin socket installed. But rather than a permanent armoured cable and waterproof socket etc, I'm thinking to install it indoors at my back entrance, then run an extension lead whenever I weld, so:
2. Will I notice any significant power drop by using a 25m extension cord?
And finally:
3. Will the orange caravan extension leads (or any other 2.5mm2 cable), work for this? (for a 16A supply of course)
Thanks in advance! I've already learned a lot from this forum but just couldn't find any exact answers to this in previous threads.
And finally:
I'll check out those online calculators, and it'll probably be a question for the electrician but if I go 4mm extension surely the initial consumer unit to socket feed should also be 4mm in that case? 2.5mm sounds fine so far though, and I've already got outdoor 13A sockets down there for grinders etc but no idea of the quality of wiring.
