Looking for an opinion on the thickness of steel I should be using for a little project.
I'm looking to make a restoration ramp style thing - basically two long ramps supported at one end that you drive the car onto and there's a beam between them at the bottom end that you stick a trolley jack under and lift so that the whole lot is level with the car a foot or so off the ground on it's wheels.
You can buy these things but they ain't cheep and you see I can stick metal together myself........ I reckon I can do it for half the price in material (possibly somewhat less).
I'm thinking 50x50x5mm angle iron down the edges of the ramps and I'm thinking a minimum of 300mm wide for the ramps. So how thick will the steel need to be for the "floor" of the ramps? I think 3mm might be a bit lightweight so was wondering about 5mm, I have priced 6mm but suspect that might be overkill (and getting pricey).
I'm looking at 3500mm length though that may come down to 3000mm.
And I'd like to occasionally lift my Discovery with it. Usually it would be much smaller stuff but if it's beefy enough to safely hold a Disco then a MINI is going to be simple.
