rcx132
Philip
- London, UK
I'm new to air con, never touched it before, this is my first time. I've got a leak, it's a worthless car so thought I'd try to find the leak myself. My brother filled the aircon system for me with Nitrogen, 80psi and put in some UV dye. That was three weeks ago, the pressure is now at 10 psi.
I've only just had a chance to put the car into a dark garage to look for the leak with a UV torch. There's nothing I can see, so the leak must be behind the dash right? There's also a HVAC thingy at the rear of the car, apparently for the rear heating (it's a people carrier). So the leak could be there.
Just thinking though, do I need to switch on the air con to distribute the dye? Since I've had the car the VAG-COM says there is an aircon error due to low pressure, so I assume I need to repressurise the system back to 80 psi and clear the VAG Com error for the pump to switch on?
