jpmillermatic
great to see you continuing this project!...a lot of work has gone into this car!.....
looks great
JP
looks great
JP
What engine was, or is going back in it?hi allapologies for lack of updates on this
just a quick update. the cortina has been filled sanded, epoxied guide coated, primed guide coated and sanded smooth View attachment 115559 front subframe dropped out and engine bay painted in 2k View attachment 115560 was a real pain in the neck getting everything covered. View attachment 115561came out ok thoughView attachment 115562 next job is painting the door shuts then the outer shell. will update when done
yes generally 1mm for body panels. chassis parts 1.2 or 1.6 jacking points were 2mm because i didn't have any of the aboveAmazing skills. Gives me hope for my Capris!
What thickness of steel do you generally bash the panels out of, 1mm?
2litre pinto standard apart from very minor head work for nowWhat engine was, or is going back in it?
a fewAny updates Ian ?
so just a quick update. this is how it sits at the moment underside painted engine, gearbox and axle painted front subframe all stripped new brakes shocks springs had the engine running and fitted the windscreen this weekend hi, yes but i'm using a generic seal and i think the main problem is in the door itself which was always harder to close than the others. think it can be sorted with a block of wood and plastic hammerFitted new door rubbers have you?
i should have tried sorting it before painting but forgot so some touching up may be required
hi, yes but i'm using a generic seal and i think the main problem is in the door itself which was always harder to close than the others. think it can be sorted with a block of wood and plastic hammeri should have tried sorting it before painting but forgot so some touching up may be required
