The radios are about 20ft away from that, in the other room. Reason I made the power supply shelf on this was because of the noisy fan in the ex-server room PSU I got years ago. Remote mounting makes it quietIs there s hidden radio transmitter and Morse key?
 Simply sitting in the relatively enclosed space of the lower shelf quitens it down a lot more, and I can build a baffle box for it to sit in, later. The other PSU next to it is of a later server generation and twice the output for half the size, and it's nearly silent as is.
 Simply sitting in the relatively enclosed space of the lower shelf quitens it down a lot more, and I can build a baffle box for it to sit in, later. The other PSU next to it is of a later server generation and twice the output for half the size, and it's nearly silent as is.it was crap end of
)Didn't make it myself, but the legs on the left belong to the guy who did. Made every part. Fires .50 cal ball or slug rounds and is fired by shotgun caps via a spring-loaded pin. Son had a go at firing it. B-hoooooom!
No picturesDidn't make it myself, but the legs on the left belong to the guy who did. Made every part. Fires .50 cal ball or slug rounds and is fired by shotgun caps via a spring-loaded pin. Son had a go at firing it. B-hoooooom!
It's in the "crap but good because it's so crap" genre. Big Trouble in Little China, Escape from New York, Remo etc. are all in that camp. Corny as hell but classics.
I'm just watching 'Convoy' for the first time, believe it or not.
What a load of old tripe, but I can see how it tapped into a mood at the time.
But you can see how Halle Berry channeled the Ali McGraw look when she did Swordfish...
Works well:
Sandblasted the heavily chipped japanning off this and treated it to some appropriately named ‘Ming Blue’. Everyone has black planes and I fancied something to give a bit of ‘pop’ when I use it. Now to find a plane to steal the handles from (I have the frog and cutters)
Tip
Having made my own dismantler four or so years ago out of a bit of scrap six inch I girder, some scaffold tube for the fulcrum and a 20 mm steel bar for the handle
I found that on a lot of pallets that have three or more bottom bearers it's best to give the middle joints a gentle tweak to loosen them slightly first, especially if collated annular resin coated nails have been used out of a high speed nailer .
Can you dismantle a pallet with 120x 120 mm wide bearers ?
First attempt at this, tbh I made it on the fly from gut feel and instinct, very little thought went into it!
The MkII is usually improved a lotAll the best inventions start out like that.
