doubleboost
- Newcastle upon Tyne England
I did not want to weld this but he insisted
It should clean up well
There was one going in to the cylinderIf that's all the same water jacket then why weld![]()
Yea just spotted itThere was one going in to the cylinder
Top right on last image
Possibly 25 thou may be 40 it runs very low CR so should not be a problemHow much do you think you will have to face head to reduce corrosion around gasket seal on cylinders
Austin I believeOld side valve Ford ?
View attachment 150274 View attachment 150275 View attachment 150276
Metal stitching is still used on cast repairs.It’s brilliant what you metal magicians can do.
Years ago I did some consultancy for Wolverton Rail works, it’s an impressive place that reconditions and maintains rolling stock
https://en.m.wikipedia.org/wiki/Wolverton_railway_works
I watched this old boy repair a casting, can’t remember what it was. It was cracked. He cut out the crack, cut a matching bit of old but new cast iron to fit, drilled some holes then hammered in some wedges. There may have been some other steps but I can’t remember. Ground it all down and it looked brand new. No heat, no welding involved at all.
Sadly the railway works, which are still there will be flattened soon to make way for housing. They have some fascinating old school machinery in there
https://www.bbc.co.uk/news/uk-england-beds-bucks-herts-45010777
The crack is drilled and tapped a stud screwed in then this is partially drilled and tapped
This is continued until the crack has been replaced with new metal
I used to know a guy in Gravesend who was involved as a tech consultant with them when they were Granges Metalock, what he didn't know about repairing on-site large expensive lumps of cast and similar wasn't worth knowing.What a interesting website
Yes AC 80 Hertz 10 % balance at 60 ampsDid you do that on AC?
