You can go thicker on material and add lightness with holes
I wouldn't try to save weight on something critical like an engine mount by weakening it with great big holes. The metal in the first picture does not look like it is 3mm, I made some for a 2.0 Pinto engine using 40mm RHS with 3mm wall and 3mm end plates. It would be better welded in one run than tacks one after the other.Heavy (for a 4 cylinder ) all cast cam in head Opel engines use 2-3mm and no thicker for the 6 cyl which was same but 2 more cylinders / near 50% heavierpersonally they should have been made from least 5mm thick for that little 4 cylinder.......
these will def fracture.........sorry.......
probably one of the best uses for a Cinasuim adjustable spanner I have ever seen .well at least there adjustable = {universal ) or were![]()
Brilliance.
