JoelC
Evening all,
Anyone use a workshop crane or hoist?
Need some ideas, I’ve had my garage extended to create a workshop area. The workshop floor is about 700mm lower than the garage floor, so I need some means of moving stuff from one level to the other. Mostly it will be light stuff, but occasionally it will be the odd engine - maybe up to 750kg. I’ve seen electric hoists that will take up to 1000kg (using a snatch block), but my trouble is how to mount it.
I thought about running two RSJ’s between the walls and then using a thick walled box section between, but I don’t know what load the single skin walls could take.
Else it would be looking at some kind of jib, either scaffold based, or steel post bolted to the concrete floor.
Anyone have any ideas?
