RaceDiagnostics
- Broughty Ferry
I had a bit of stainless steel tube off cut just the right diameter to use to push the bearing back on to my hubs, but the tube ends weren't square.
I thought about searching for somewhere close locally that could trim the ends then remembered my miter saw up in the loft, I also was pretty sure it had a blade with carbide tips, so whats to lose, just a saw blade I never use.
I tried out first on a mild steel bar and it cut just fine so went ahead on the stainless tube.
It cut through that also no problem.
Not sure how long the blade will last but will try it again sometime.
