Jacktegla
- Denbighshire
It is cast would that matterI am sure someone on here would do it for you, great bunch of lads.
Just did a little test piece, it's thin but I don't think so thin you'll need to bore the pulley out.But the motor shaft isn’t long enough either. The only idea I had was to make a sleeve for the shaft and the pully would need boring out but I don’t have a lathe
I drew a rough sketchJust did a little test piece, it's thin but I don't think so thin you'll need to bore the pulley out.
Lemme know how long the shaft is and how long the part needs to be and I'll make it for you.
Do you think it would work I know someone else who doesn’t think extending the shaft would work for that long ( only a year or two ) and be strong enough but I don’t see why notJust did a little test piece, it's thin but I don't think so thin you'll need to bore the pulley out.
that's no use 1.8mm bigger than the motor shaftI drew a rough sketch
It would ideally be 145mm in length all together
bore the pulley out larger then sleeve it giving enough meat on the sleeveHaven’t got anywhere to bore it out so ‘maker’ Was my best option of just giving it a go and hoping for the bestthat's no use 1.8mm bigger than the motor shaftbore the pulley out larger then sleeve it giving enough meat on the sleeve
Preferably would take out 1-2mm from the pulleythat's no use 1.8mm bigger than the motor shaftbore the pulley out larger then sleeve it giving enough meat on the sleeve
Oops, that's much longer than I was expecting. You could possibly get away with it but it's really pushing it, a tight belt on the highest speed might fatigue and break the spacer right at the end of the shaft after a few months use.
I agree with Diesel, the old motor will look a lot nice than these new aluminium finned ones...![]()
Cheers will have to keep an eye out on eBayJust checked, mine is a BTH 1/3hp running 1440rpm.
Cheers anyway will keep an eye out on eBayOops, that's much longer than I was expecting. You could possibly get away with it but it's really pushing it, a tight belt on the highest speed might fatigue and break the spacer right at the end of the shaft after a few months use.
No it didn’t come with oneIs the old motor broken or something?
