Something like that it's too bolt a chain to my jetski trailer to secure the ski to when not in use to deter the little scrotes the ones I have seen have been a cone shape with 3 slots in them that I'd think a special spanner goes on to put them onDo you mean shear bolts ?.
https://www.google.com/search?q=she...3rjcAhVHKMAKHV83DD4Q_AUICygC&biw=1920&bih=954
I'm thinking something like m8/10 around 40-50 mm long but I'll have to double check and if you have something like that it would be greatWhat size do you need? I have so.e you could have but they're pretty big
I'll check tomorrow :-)
I can't put a weld on its too far away from homeJust use a normal bolt and put a blob of weld on the nut?
They'll only cut the chain instead.
Yeah I do it's a 15mm hardend chainhope u got a good chain ?
I'll see what happens I'd like something that fits without sharp edgesTake regular threaded stud, put a cross cut in the end with a hacksaw. Fasten up and then peen the end to spread it and the nut cannot be removed without a grinder etc.
My std with security shuuers and such. If they bring cutting gear anything is done for
There are no sharp edges - you peen it! You only need a couple of mm to lack the nut and as you peen you are deburring.I can't put a weld on its too far away from home
I thought you meant cut and fold both sides like a split pin I'll give it a goThere are no sharp edges - you peen it! You only need a couple of mm to lack the nut and as you peen you are deburring.
I'll give that goTo be clear cut a cross in the end and take a ball hammer and spread the last section of thread out so it cannot be unthreaded. I mean you don't need to do much but if you realy wanted to you could given time form a type of rivet head, pointless but possible
I'm of up to it tomorrow so I'll messur the threds and let you knowI forgot to check... I'll look in the morning
Iirc they're m10
They're the kind that snaps off leaving a little time behind
Nuts and bolts iirc
In fairness I never secure my gates from theft.. It's incredibly rare here to have gates stolen. Scrap is low and second hand gates no matter how nice are hard as heck to sell for decent money and very identifiableDo both? Shear nut + pein. That's what I did on some gates I recently finished, though I didn't first cut the thread as Kent does.View attachment 148609 View attachment 148610 View attachment 148611
