Sorry, yes air hose. Thanks. Off to Screwfix now.Assume you mean air hose? Plug on one end and socket on the other. Socket on the compressor and plug on the tool.
There is no pot fitting to dictate the hose fitting. But I now know what I need.you will use the hose. a plug on one end that goes in comp socket outlet other end is a socket and that that pushes on to the plug on your pot feed
Which bit, the whole job, or adding more air?don't hold your breath![]()
I have a small Stanwell 3.7cfm 100psi compressor as well, Dcal previously said not to bother with it, but it would give me virtually 30% more airflow if I put them in tandem? what am I missing? Edit just found his post and it my be the hassle factor in that it needs a bit of tlc.
Cheers.
more
air the better
Yeah, I'm feeling that way right now.Every little helps.
I have a tub of that. Will try today on the round thing.See the other post about brick acid.
BeforeSee the other post about brick acid.
