oceanobsession
Hello again everyone. tonight ive spent a hour trying to weld vertical ive a few questions.
do you put the rod in horizontal. also amperage seems crucial. ive tried the
triangle method stopping in each corner. im under the impression that the line
across the bottom of your triangle once set you go up stop down stop then come
accross the bottom again slightly higher resting this weld on the previous one
i can also see why you would shampher a tube helping to keep in the weld at the sides l only having to concentrate on the bottom. i did manage to get a ok weld
improving the shorter the rod due to better position any help very welcome
cheers ocean
cheers ocean
ooh, and here!-
