(a)isn’t a common dimensional factor when we talk about fillet welds generally any more. More often we refer to (z) now which is leg length. I actually like to use both because they represent different things when talking about the soundness of a fillet. You might have a 4mm throat but your last weld represents very clearly the leg length ain’t well matched to that throat. A good rule of thumb to work with is Z x 0.7.= a
If this adds up something close then your not far off a well matched dimensional fillet. So you’ve got a 4mm throat so your leg length wants to be around 6mm.
You’ve also got toe transition issues with that weld in the bottom pic which is another story.
thats the point.No real idea what you're on about! But that bottom 'weld' is garbage. Not sure if that's your point or not.
He needs some practice.the bottom pic is not my work Richard, as i said theres a certified welder who welds like that
yes it isYour 'certified' welder looks like hes suffering from the hangover of the century.
Is the first picture a single pass?
