Duck
- UK
There was a leak on my steering rack. It's a £300 spare car so I just put in some leak-stop fluid. It didn't work and the leak was bad so I'm replacing the steering rack.
Some of the fluid with the leak-top additive spilled onto the tyre. The tyre swelled up. So that's how the stuff works, it swells the rubber seals (and has wrecked my tyre). I really want that c**p out the system before I fit the new steering rack.
Just trying to figure out how best to flush it out. Found the circuit diagram below. So it looks that if the steering wheel is not being moved then the hydraulic fluid just circulates between the pump and the orbital valve and reservoir.
My steering rack is removed. So if I fill the system with cheapo oil and run the engine then the oil will just circulate. So I can change it several times.
If I then turn my steering wheel then it will divert oil down one of the hoses to the rack to flush that. Then turn the wheel the other way to flush the other hose.
Is this a sound plan?
