High level steps are roughly:Im so tempted about getting one and trying to learn something new.
@130 Is there any basics that I will need to know before getting into it??
Now step 4 may be draw something in cad and export to STL file.
- Assemble printer
- Buy printer consumables - PLA filament
- Install software that comes with printer
- Download a model stl file, for example from thingiverse
- Configure size and how solid (10% fill is my nibbler holder, so mostly hollow inside, 100% = solid)
- Export that to a Gcode file onto a memory stick (micro SD and adapter came with A8)
- Put memory card in printer
- Select and print the thing.
With the Anet A8 I found certain numbers for shell thickness etc gave me much quicker prints
Depends a bit what you are buying.
If you are PC literate to the level of installing normal printers and software, and either buy one assembled or like the Anet A8 kit I found the assembly guide PDF a bit hard work but following the guy doing it on you tube, watch a bit then pause while doing, easy.
I hadn't done tech drawing since O level and never CAD so watched a few tutorials. Took a while to get into it and I keep getting better. Drawing is the hard bit
I've just got a nice one inch thick piece of marble fire hearth that's earmarked for the base.^ Bargain.
First action is to cut yourself a piece of MDF or something stable and go through bet levelling procedure once on it.
Mine has some clips printed and is screwed down to a piece of MDF
Have a look at Octoprint, I've got it on a RaspberryPi that the printer is plugged into, after step 5, I send the gcode via WiFi to the RaspberryPi and then if I want I can turn off my PC and leave Octoprint & the 3d printer to do it's stuff. It's really handy if you have something that is gonna take loads of hours to print.High level steps are roughly:
- Assemble printer
What you going to print first?I've just got a nice one inch thick piece of marble fire hearth that's earmarked for the base.
A benchy.What you going to print first?
I'll second that....what a mess those crescent chips make and they get EVERYWHERE!![]()
Hi rise funnel and oil / water "spanner"
One side is for the oil and one side is for the rad cap because my wife struggles to undo them to check her oilIs that spanner 38mm to fit the oil filter housing lid? If so, would you be prepared to do one for me and what would you want for it price-wise?
It'd save dragging out the 3/4" socket set when the change is due, although co-incidentally I just did it earlier this week.
EDIT: Just had another look at the pic & I realise it's for the filler cap, because yours in more difficult to get at than mine. In which case, please ignore the question(s).......![]()
The funnel is just because these are a beggar to pour oil in without spilling for anyone.
The thing you are after is one of these?
https://www.thingiverse.com/thing:1480117
https://www.thingiverse.com/thing:2300861
Second takes a lot less material
