I am sure its not just as simple as this brand or that brand. I used to run Michelin and i have never had tyres last so long. In contrast in anything but dry they were useless.We tend to run branded makes on our cars, funny one when Mrs Robo took her Pug in for a service, they noted her Toyo tyres as "budget brand", apparently Peugeot dealers only recognise Michelins as premium tyres![]()
Not as good as the A509 IMHO, I have had both on my VW Pickup that was running a bored out tuned up GTI engine in it. I could definitely push it harder with the 509's especially in the wet than when I had 539's on it but the 539 was still a good tyre.The a539 was an amazing get tyre also @wookie
I was impressed with some Matador's which are apparently a sister company to Continental.
But a lot of the budget stuff is dreadful, ditch finding nonsense
Maybe they had improved since then!Jesus, they used to make us race on Matadors, they were god-damned awful tyres.
just changed my front 2 tyres,
Firestones and similar were €80 apeice.......had Barums in the past so decided a change.......these were €52 a peice.......same noise and wet weather spec plus slightly hire speed rating 112 instead 108........
will let u know........
normally I buy quality tires firestone continental etc . when driving hard in the wet on quality tires they grip realy well round the bends doing 70 mphI generally shove it till you start to slide out . the stopping distance is real good . took it to the garage get a ball joint changed and tires were in a bad state on the inner edge so they changed them without askin me what type .they put a couple of new ones on the front 3d world tires called sailwind
there fine in the dry at high speed cornering but in the wet there something else . ditchfinders
setting off you do wheel spins and at anything over 60 round bends and your sliding out . the stopping distants are abysmal specially if u drive to close to other cars
its frightening . the story is buy good branded tires they last longer and make it a lot safer when driving
For balance, budget (ish) tyres can have a place.
I've moved from pretty decent Bridgestone battle-axes to really quite cheap "maxxis" ones (about £55) for the back of my big bike.
Reasons being, I don't bother riding in wet much at all and onlyy in summer, and due to the type of miles, whatevers on there gets flatter off.
A cheaper tyre means there is no question I'll put a fresh one on at the start of every summer. If there were 1/3 tread left on a "good" tyre I'd be tempted to use it up. It's much nicer to jump on a bike with a round profile tyre after a time of abstainance.
Maybe that's not fair though as, for the price, they do get reasonable reviews.
Ran maxxis supermaxx on my r1 for years with no issues. Did get convinced once to try the 3ds with the fully wet tread on the outers, pretty good in the wet but didn’t get on with the shuffling in the dry when leant right overMaxxis only on the rear of the GS850 for me. M&P knock them out at a decent price and they last well, with decent grip. I give them some stick around here, too.
The worst one was a Kenda - turned out the cause of it aquaplaning was the tread pattern (copied from some Dunlop, iirc) was the wrong way around to clear water. I fitted a later Kenda with a quite different pattern (again, a copy of something else) and it was like night and day.
Maxxis themselves are a brand of Cheng Shin - used to be CS was the ultimate ditchfinder, but they got their act together and bought the rights (and possibly the entire production line) from Yokohama (iirc) to produce their tyres under the CS name. The name was a problem though, so they re-branded as Maxxis for the European market and hoped nobody would realise.
It worked well, it must be said. I've not had an anxious moment on a Maxxis, but then again even though I tend to welly it around, it's not dealing with mega horsepower at the back wheel. The front in wet and dry is absolutely fine, for me anyway.
Worst tyres I’ve had on a bike were a set of conti attacks, felt like the front end was pushing out on every corner, absolutely no confidenceCheng Shin!
"The name was a problem though, so they re-branded as Maxxis for the European market and hoped nobody would realise"
I never realized!
Never had Maxxis though but people have said they are pretty good.
I had a pair of Avon road / sport tyres on the TRX for a few years and they were rubbish!
Had rear wheel slides in the heat of summer with very little provocation. No feel nothing.
Got a set of Continental Road Attack 2 and the difference is very noticeable. I would be happy on a track day with these tyres!
I'm in National Tyres right now having a pair of new tyres on the van, crist knows what they'll fit.....![]()
That's what my little 125 had on they just about suited to that the CBR has a set of Metzeler Mes3s on but I'm don't think it will be long before they need changingWorst tyres I’ve had on a bike were a set of conti attacks, felt like the front end was pushing out on every corner, absolutely no confidence
