I didn't know I was going to phone them on Monday it seams cheap at 830+vat for the lot it's in good shape and is supposed to be serviced before purchase but if it's 3ph it's no goodYes unless it’s 160 amp. The 200/250 is 3 phase.
Defo 3 phase. 250 amp.Think it is the 255 that West Country have for sale.
Aristo tigs are very old machinesI didn't know I was going to phone them on Monday it seams cheap at 830+vat for the lot it's in good shape and is supposed to be serviced before purchase but if it's 3ph it's no good
Something like that would have been perfect as wellAristo tigs are very old machines
They were made in Laxa Sweden and built extremely well
Because of there age they are not that efficient compared to modern inverters
They did 3 current capacities of it.
160 amp single phase and 200/250 amp 3 phase.
Yeah today and tomorrow you should have seen the bike there's a picture and I think a video of it on the tg fb pageFlip I didn't even know they were having a vat free day I get quite a few bits and steel from TG
When he got it reved up like you would in staging it was deafening and you could feel itI will have a look I bet that thing takes some keeping upright with that power
Wish you hadn’t.Went to see about a parweld but they couldn't do it for 900 since they would only be getting one in but then the jasic rep remembered he had a 200 acdc analog in his boot that they could do for 900 so I just got that
Not a great machine, it’s also only 160A on AC. Was the rep called Jerry by chance?Went to see about a parweld but they couldn't do it for 900 since they would only be getting one in but then the jasic rep remembered he had a 200 acdc analog in his boot that they could do for 900 so I just got that
I used one at a small distributor exhibition up north. I found it was quite a rattly behaviour on ac. Tinny, fluttery not stable at all.Not a great machine, it’s also only 160A on AC. Was the rep called Jerry by chance?
On ac its 200 amps it shows 200 on the displayNot a great machine, it’s also only 160A on AC. Was the rep called Jerry by chance?
The rep said that they were the same as the mini one just instead of buttons you had knobs to adjust it withWish you hadn’t.
Others might disagree but I found it to be quite an awful machine
It's a bridge the gap machine till I have enough for a lorch I got on with it okay in the hour I was using it before I'll put a picture up of some of what I did in a minuteI used one at a small distributor exhibition up north. I found it was quite a rattly behaviour on ac. Tinny, fluttery not stable at all.
@Jlg you May be ok as I don’t think you’ve had one to compare it too and you’ll get on with it but don’t rush out now to go try a parweld or thermal arc or new digital rtech will ya because you’ll be gutted as they perform a lot nicer.
