Also I’d like to change the oil, can’t see a “sump plug” anywhere to get the old stuff out.
Seems to run upto 150 psi then cut off, there’s no pressure regulator on it as of yet by the looks of it.
Is that not a plug on the bottom right of the crankcase?
Looks like the pump is being copied nowadays by Fusheng (unless they made it in 1982, of course).
https://www.toolex.com.au/products/593508
Reading the blurb on that advert, it's possible it might be original. It's probably a good one, at that.
The switch has a regulator built into it.
Do you think I should be concerned about it being 36 years old?
