normspanners
no you only need a very small drain pipe brake pipe would do, but the 47kg are 3/4 bsp anyway.I think I remember that, with the size of the thread in the top of a tank it would be quite restrictive.
Didn't know it was considered a safe thing to do, thanks.
Hydrotested....pressure testing with gas / air is much much more dangerous. From memory it "should" be a strength test to 150% of MAWP.They should, if doing things by the book, be pressure tested after making any physical alterations to the tank.
Any scientific proof of this or is it just internet gossip, I'd be interested in seeing the paper?The propane can even contaminate the metal
No a guy lost his face about 18 months ago on some road works. Old fuel tank had been cleaned but then stood. Horrific accident.Any scientific proof of this or is it just internet gossip, I'd be interested in seeing the paper?
Its OK it won't be me feeling guilty or worse if you join the rank of those who copped for the possible outcome that does happen sometimesBecause I can get free propane tanks (Gypsies aren't all bad) and people like Bill and BS who's opinions I'd trust say it's fine. That's not to say I don't trust your opinion (Quite the opposite actually
) but there's more of them and they said it first.
EDIT: That reads more argumentative than I intended, hopefully it comes across more of a discussion than an argument.![]()
Did you pay for a half hour argument or a five minute one ? because some of this is contradiction, or is that a discussion ?------ ding thanks your 5 mins are up.That reads more argumentative than I intended, hopefully it comes across more of a discussion than an argument.![]()
3/4 bsp has about 3/4 hole,I'll probably put a bigger one on the side for a less restricted output too.
I am being "deadly" serious BTW. The propane can even contaminate the metal
. I always fill the bottles with water and let them stand full for a few days before cutting or welding.
Washing up liquid removes the lingering smell, hence my instructions.
It would be quite difficult to make a dangerous weld for a fitting. The slightest hole will cause air to leak, which means that provided it’s airtight it’s joined right round.
I think you would struggle to make an airtight joint with zero penetration.
Even most hobby migs would suffice, the metal involved is actually not very thick.
YEP 3mm makes you laugh RE the old receivers, 3/8 boiler plate and 160 psi working pressure and them failing insurance certs for a BIT of pitting !! even half rusted through and they were still thicker, in reality there is not much chance of them going bang the amount of truck ones that pit through , all that happens is they just end up leaking.About 3mm if I remember correctly.
cant see it being 1/2 mm !!
