anto44
- ireland
It's your On Board Diagnostics plug. The plug that you use to connect code readers to your car.Whats the obd plug?
I used to take the ecu out of my evo and put it in the birds handbag when we were off anywhere
is it removeable?It's your On Board Diagnostics plug. The plug that you use to connect code readers to your car.
I have read about OBD ports being rewired so the usual code reader thingy doesn't work. You then have to rewire your own code reader to match.
Another option is a discrete switch in the wire to pin 16 (+12 volt supply)
