RaceDiagnostics
- Broughty Ferry
I always use a 2k high build primer over epoxy as its easier to sand and get a nice finish for the base coat.
I think that's what we're talking about. Lechler call it "HS Rapid Filler "I always use a 2k high build primer over epoxy as its easier to sand and get a nice finish for the base coat.
@ajlelectronics, with incompatibility issues, any reason not to just stick with one paint system, e.g. Lechler, then compatibility is guaranteed?
Sounds like a good idea. I should have phoned Lechler to get the right products.I use the LS105 high build primer rather than the Green (which is popular here), as it is from the same range as the LS107 Epoxy. They are both from the "Lechsys" range, part numbers LS105 and LS107.
