Yes, replaced the wheel bearings on the Spec B and may have also changed the drivers side on the Outback, can't remember for sure.Yep same 6 speed casing but with Hawkeye sti gear ratios just with a longer final drive,
The wheel bearings are bolt on items, nice and easy to change.
Yes still have it, it is minus a passenger seat though as that is now my computer chairHappily buy most spec b''s we can get hold of if cheap money! Especially if manual. Do you still have it??
They do have a little whine due to the step off gear but shouldn't be "noticable" as such.
Well see if the problem manifests itself on the drive downNot far from you, probably only 500 miles or so![]()
Spec B with outback behind. Outback was the wifes so was clean, Spec B was mine so never washed. I now have the outback so it is the same state as the Spec B was
. Turns out they used plastic cages on the pinion bearings on some of the US spec Foresters, and when the cage gets tired all the rollers jump out and the pinion climbs out of mesh, usually under load, and your diff destroys itself, post haste and with little or no warning. AFAIK, at least about the NA spec Subies in the '99 to 2008 range, they have used 4 basic types of center diffs; torsens on the STIs and some of the WRXs, viscous coupling on most WRXs and manuals, an in-house designed and made electro-hydraulic actuated clutch pack in the early production (like a Haldex set-up), and finally a Haldex clutch pack on the later cars to current. Don't know if it applies to all of them, but on the early to mid 2006 or so automatics, you could pull a fuse that would uncouple the center diff and force the car to run in 2wd with the ABS defeated. Might help with pinning things down. We used to check out the health of the 4wd by running the cars in tight figure-8s on pavement, which would load up all the drivetrain parts in in any way we could concieve. It would usually point out marginal CV joints, clutches in the center and rear diffs, bad spider gears, etc. pretty quickly.Ok will have to check that out, maybe no oil in itYes, duff runs 75w90 and gearbox runs atf
