dazza
- Barcelona
After a bit of use with a wire wheel my grinder is making a weird noise every now and then but especially when you switch off and its winding down.
Also went through a cutting disk removing two hinges. Should there be play in the spindle
Is it safe to use?
?Is it safe to use?
and added some fresh grease the gears were dry. It still has a tiny bit of play but much better and no noise. The circlip did not have much spring hopefully it will hold. Just need one more grinder now
