As BS said, There are a few ally "brazing" rod makes, Excellent products if used correctly, I think from memory they work around 350ish degrees, For a small job a gas/propane torch is quite hot enough.
Just be careful when you use them, especially on ally that thin. The filler rods melts at nearly the same temp as ally & it can easily become a mess. I would suggest practicing on some scrap first.
