powderblast
- Hull, UK
Hi does anyone know were the cheapest place is to buy m48 washers self color ideally so i can weld them.
cannot open link but i need the hole (id) to be 50mm so i can slide the washer onto the 50mm pipe and weld it onAre these discs from Brundles any good -
http://www.fhbrundle.co.uk/groups/0521__Steel_Discs
or cut one with a couple of hole cuttersplasma them out of some sheet ?
would that mean a 50mm washercannot open link but i need the hole (id) to be 50mm so i can slide the washer onto the 50mm pipe and weld it on
An M48 washer is 50mm id x 92 od x 8 thickwould that mean a 50mm washer![]()
Another vote for them, I've had lots of parts made for trophies or targets by LM, often from bitmap silhouettes.I am a big fan of Lasermaster. Order on line - https://www.lasermaster.co.uk/easy-order
