Not so on the straight beads however hahabYou seem to of got a good thing going on the fillets.
I found it hard to stay going straight when welding across a flat bit of plate cause there's no edge to follow along like there is on an actual joint. I found scribbing a heavy line into the metal helped. It looks like a tightly fitted up butt joint when you're welding it and gives you something to guide youNot so on the straight beads however hahab
That’s a good idea, very good. I will try that. I can’t draw a straight line with a pen let alone tig one hahaI found it hard to stay going straight when welding across a flat bit of plate cause there's no edge to follow along like there is on an actual joint. I found scribbing a heavy line into the metal helped. It looks like a tightly fitted up butt joint when you're welding it and gives you something to guide you
Thanks Paul, very nicely done in that video. I’ll givd that a try next time I’m doing some later in the week or tomorrow maybeRather than a pen mark, a scribe line or a row of centre pinch marks is good to follow while you are learning, but the best thing to be welding is a joint, we don't get many jobs where you just lay beads on plate unless you are surfacing or reclaiming something.
To prevent your crater at the end of the weld backstep a little as I do in this tutorial video, the black shiny thing in the craters on your welds above is melted scale from the plate, its contaminating the weld puddle and floating to the top.
http://www.mig-welding.co.uk/tig-technique/tig-bead.mp4
It was the side of the rod not the end. It created a short I guess which caused it to stick.Disclaimer first - I'm no tiggist
If your filler touched that other bit of stock you're pulling it far too far away between 'dips' (unless it happened after you finished).
Ish, I’m fighting the flu and was trying to tidy the garage so I could get to my bench at the time. I’ll spend some more time with you kim when I’m not dyingThey look awesome. Well done Kim.
Do you now have a firm understanding of the TA’s ac settings.
A woman who welds but youd rather die....i dont know what are men made of these days.Ish, I’m fighting the flu and was trying to tidy the garage so I could get to my bench at the time. I’ll spend some more time with you kim when I’m not dying![]()
Looks to me like your guidance was spot on mate.Ish, I’m fighting the flu and was trying to tidy the garage so I could get to my bench at the time. I’ll spend some more time with you kim when I’m not dying![]()
Ummmmm, maybe haha. Not really. Tiny bit but obviously not well enough to properly set it on my own. What I may do is take the base figures over power and under power certain things and see how it reacts.They look awesome. Well done Kim.
You carrying on dying. Least I won’t have to hear the tragic stories of you wanting a bmwIsh, I’m fighting the flu and was trying to tidy the garage so I could get to my bench at the time. I’ll spend some more time with you kim when I’m not dying![]()
I’d love that but I don’t have any. Ali for me will be a bit few and far between. I’ll see what I can get ahold of, I’m not going to buy a sheet just for tig welding practice.A woman who welds but youd rather die....i dont know what are men made of these days.
Excellent progress Kim. Might I suggest you use nice new clean metal to practice, to remove some of the unkowns
Stick a drop of postage brass in my PayPal and I’ll send you some 2mm 1050 off cuts if you like.I’d love that but I don’t have any. Ali for me will be a bit few and far between. I’ll see what I can get ahold of, I’m not going to buy a sheet just for tig welding practice.
That’d be amazingStick a drop of postage brass in my PayPal and I’ll send you some 2mm 1050 off cuts if you like.
Perfect to practice on
