I have a gas economiser i fit in line if doing a lot of oxy welding, when you put the torch down flame goes out, then when you pick it up again you just light if from the pilot flame and off you go no re setting the torch. Well worth the cost in both gas and time saved.I’ve read a lot of American restoration books were they advocate Oxy Acetylene welding because you can planish the weld while still hot to flatten it out & virtually avoid grinding altogether. They even show torch cradles so you can put the lit torch down & quickly grab a hammer/dolly to flatten the weld.
RonA
Yes I think that I have noticed the effect but I am not sure the explanation is correct, I am sure one of the metallurgists will be along to explain why.I've noticed mig is harder than tig when it comes to machining parts in the lathe. For example building up a worn area on a pulley or shaft.
I was told by an experienced welder this is due to mig wire being made of a harder composition to withstand being pushed from the machine to the torch.
I've never seen one of those before, that's really cool. So top right has a little pilot flame and hanging the torch kills the gas? I guess the only concern is of the torch gets knocked off the hook without you realising.
Likewise until i stumbled upon one on eBay poorly describes as something like "welding torch and hose bracket" Still in its box as NOS.Then I saw the price and decided I could live with that for now...
I only used oxy/a on cars etc until I got my mig and then the oxy/a was put on the back burner (excuse the pun) except for loosening seized components etc, could make some seriously smooth welds with oxy/a but that was over a 100 year ago.oxy acet welding is far smoother than mig and hardly needs anything grinding off it the metal is not softer it just doesn't leave lumps to grind off if u are proficient at gas welding
Aye
Are you really that old?
