Wildefalcon
- Gloucestershire, England
On stainless screws, I picked them as they are much more likely to shear off.
Can any one guess why?
If it's to stop nefarious characters from unscrewing them that only works at all if the screws are fully threaded.
And if they shear at the head...
Any good quality roofing membrane should siffice....and speaking of insulation (membrane) as the thread suggests, any particular type that's worth looking at? I have looked over a few but as yet a decision is still to be made.
A huge factor here is board size and quality.
Cheap nasty 4"x3/8 itll be awful, 6 inch by 11/4 inch....will be a good substansial shed.
If they take my boards off they will be met with battons moisture paper and 22mm tarred ply rescued from an old flat roof.Exactly.
Fully threaded, and they do shear.
Very true, I cheaped out on some Travis perkins 6" feather edge when I clad the outside of a stable block, its now shrunk to 5" , lost its lap and has curled . I never gave it much thought at the time but this gear is stored outside in banded packs so if buying in the winter will be sodden and fully expanded, only one way to go after this so my advice would be to make sure its dry when installing it.
I put this pic up before. My nipper wanted a shed for his motocross bike , I was offered a fridge body for next to nothing so plonked that down on the ground. No drafts, condensation and bodyheat alone will warm it. If one of these were timber clad it would make a great shed for a lathe/mill.
Bob
take a moisture meter with u when u purchase and give the wood a prod see what moisture content is in it![]()
The featheredge timber I built my shed from came from a local mill and as far as I know was pretty fresh.
3 years later it's grey, but it's not warped or shrunk.
Mine wasn't pressure treated (or treated at all) - the plan from the start was to let it's own oils look after it for a few years then creosote, which I'll apply this year.
Pretty sure it's spruce.
Price wise, I had it cut into 6' lengths to suit my modular design and I'm sure it was well under £2 per length (about 90p or so per metre rings a bell).
I hope your using genuine creosote and not the substitute crapMine wasn't pressure treated (or treated at all) - the plan from the start was to let it's own oils look after it for a few years then creosote, which I'll apply this year.
It will be fairly wet as will have been pressure treated. Id go the man ll route unless you can hand pick your wood. Heavier size the bettter
Mine was all fairly dry when I loaded it at the timber yard but it was our 4 days of summer
- 100mm wide and 12mm at thickest tapering to about 6mm. It was so wet when the screws tightened it was sqeezing water out.
