Duck
- UK
I've been reassembling my Suzuki Vitara, it's had 3" suspension lift and one of the problems the lift has caused has been that the handbrake cables don't reach the axle when the axle is at the bottom of it's travel. Usual solution is to undo the middle locating clips so that the cables can basically short cut. But this means they now flap around and rub on the suspension links.
I think I read that you can make own control cables by cutting to length and silver soldering the nipples onto the ends. Does this sound right? My friend has a lathe so can make the nipples. I've never silver soldered but can't be too hard, I have an Oxy-MAP torch.
