Snail brand are one of the chunkiest spanners I've come across. They truly are meaty. Superslims tend to be one of my favourite spanners for general use though.
There you go just as you wrote it
It's too cold to be going out and de-icing the shed lock to see what I have lurking in the tool box. I know some of them were my Dad's - and he's been dead for 40+ years.
That's the ones. I just tend to find those comfy to use, and you know you can lean on them without worry.
I wonder if it's a broken ratcheting ring spanner?here's a weird spanner, never found what it's for![]()
I like them to but I'm using imperial less and less
I have been considering getting some metric superslim's but they come at a premium I have noticed second-hand.
Funny really because as a kid I used to turn my nose up at these superslim's of my dad's thinking they were nasty black horrible things. The shiny ones as I kid I thought were the bees knees
I have got doubled up sizes in some superslim's. There appears at some point they changed the die's for the forging somewhat when you put them against each other.
From what I recall, Superslim spanners were also available in chrome finish. One of the traditional ironmongers had a display board with both on side by side. The black ones were the cheap & cheerful range, but strong & extremely good value. This would be in the mid '60s
All the more reason to go out and spray some oil on them in this weather![]()
But mine IS Mr VarkAnd mine is not a King Dick.![]()
The adjustable could be 'Domino' brand. I've one the same. It's lightly stamped into the head I seem to recall.
...... not a spanner but definitely vintage, how many recognise the tool in the second picture?
Yes it is, made by Terrys for doing side valves, my father called it a valve lifter, which on a side valve would be correct I suppose. I used it when I was about 16 to do the valves on a series 1 Morris 8. At a guess, it dates from the late 20s to early 30s.I include a different view so you can see it better. Your picture of the Bedford spanner Hood, that is the make, around in the sixties at the heyday of good British spanners.Is it a spring compressor of some sort?
