Thrashsmith
Hi all,
I'm quoting for a pair of small but weighty solid gates approx 1m x 1m each (around 50kg each) that are going to be hung off new 100mm hollow posts that will also be part of the installation. I was given a good idea a while ago by a local fabrication firm to weld plate squares to the bottoms of the posts so that the posts can get bolted to concrete blocks 500mm below ground level, that gives flexibility in the installation as the posts can be shimmed about to get them level rather than just concreteing them in.
I know naff all about groundworks. What sort of size concrete block would you image each gate would need for the hanging post to be bolted to? Merci buckets!
