That's what I noticed Pete. My saw is very good but it's still 0.2mm out of square on the vertical and the centre noticed it straight away. I faced off the short pipe unsupported and then refit it which then it ran bang on.That's a handy job Richard.
The only trouble with pipe centres comes if the pipe is not cut square, it makes it run out of true.
I've picked it up.
It's a little ml10.
I have put it together this evening and started turning things.
Well I must say for a little lathe it's a very good accurate tool. I turned down, faced off and internally bored out some short sections of pipe to practice with and really enjoyed it.
I paid £600 for it with just about every possible addition you can imagine so I'll have no prob getting that back. Its the newer metric version too which I like.
I'll want a bigger one I'm sure in 3-6 months when I'm more acute with it. For its size it's a really usable thing (for me).
It's even got a milling slide with vice (doubt it's gonna get used) both steadys, Pratt 3/4 jaws, live centres , jaCubs drill, 2 post quick release tool post. And loads more. I had a car full of stuff. Solid thing without a fraction of play.
Motor clicks mind so I'm gonna check the fan on the shaft Tomoz see if it needs tightening.
All in all it's great for practice and turning things less than a foot long.
You know what mate there has been loads of times when I've thought "yeah time for a Bantum" but I've never actually taken it any further than that. I could now fit a bigger one in too after a recent move around. Tbf it's used more frequently than I imagined but the capacity I'm using it for has always been on such a small scale. I use the V slide a lot too for small slots and key ways it's great. There is really no need to go bigger. Yes I would love it and I'm sure I'd use it more but I'm turning small bespoke Alu fittings mostly. Done a few bearing collars, spacers, pins , it's all small work. Accuracy is what I need not size. It does that very well and I take very good care of it.well its over a year now for this have you decided to stick with what you have or have you decided to change and upgrade your machine to another
though thread has gone really quiet so what have you made recently using it ?
Yes then leading link.This is the front fork assembly that he intends to copy. He is building a complete trike eventually. I’m doing the bits he can’t do. Like the machining and the aluminium welding.
It’s gonna be the 2nd one he’s built. It’s got a 2.0L pinto lump to go into it so it’s gonna be pokeyYes then leading link.
