,Nah, use transformer oil. It'll smell less like old fish and chips when it gets hot.
Never heard that one myself. People go to great lengths to find exactly the correct type of oil so emptying the mrs's chip pan into it wont do any good.
Plus you'll get bits of batter in the weld which won't give a very nice joint.
yes did seem a bit fishy lol but he assured us he was not joking and the mrs wont be happy using her cooking oil lol
If you do go with the cooking oil
I'll have fish & chips twice, tinned roe and a battered sausage![]()
i have a oil filled arc welder some one said you can use cooking oil to top it up or replace it i thought it he was taking the p*** but he is a welding tutor and assured us it was no joke what do you guys think have you heard this before ?
I can believe it. As I think Aero has said, there's no way an oil filled welder will get anywhere near the temperature of a chip pan in normal use so scare stories about chip pan smells and fires simply aren't valid. A top-up might be a bit risky because you would contaminate all your original transformer oil but you could always give it a try with a full load of vegetable oil. I'm sure the proper Shell oil is optimal but it gets back to the Pareto type argument - you might get 80% of the benefit for 20% (or perhaps nearer 3%) of the cost of the proper oil. Car engine oil (new of course) must be worth a try, also. Has your tutor tried that? As for insulation properties, I must experiment but I'm not suggesting anybody else should: put a 2 amp fuse in a 240v mains plug. Wire it up to two steel or copper rods carefully positioned about one quarter inch apart, with only (i) vegetable oil and (ii) engine oil between them. Would there be a short? Would the fuse blow? Would there be any bubbles or other signs of electrolytic activity? I doubt it. Measure any current flows and resistances, as well.
Why even consider saving pennies on putting the wrong oil into a welder?
You splash out and buy the right oil, which isnt gonna break the bank - you know the welder is gonna run right - it's not as if you have to refill it all the time.
