Screwdriver
I need to drain a basement with only 2 inches of water but spread over a huge area. A submersible pump wont get down to the last few mm (it wont even start to pump at 2 inches) so I am planning to use a small pump to fill a bucket and run a head pump from the bucket to lift it the 5 metres or so to the surface.
I have a solution for keeping both pumps primed and happy.
Don't want to use a drill powered pump, I need a decent suction pump (diaphragm?) and it needs to be fairly chunky and able to run for a day or two. I'll work out the total when I get back to the desktop.
Happy to look at basically anything that might work and also happy to make up whatever may be needed as a little construction project. I do need something in a hurry though so your input will be greatly appreciated.
S.
S.
