slim_boy_fat
- Scottish Highlands
A non working high velocity fan for a quid.
I might have spotted the issue...
When I say "encapsulated" I mean can't get to it without wrecking the whole thing.Bypass it or tape another onto the field winding.
Is that how old the cable with red in it is my grandad gave me a full roll of twin and Earth with those coulersproper widow maker that
I got a sewing machine with supposedly a duff motor, checked RCD tripped, bought another motor (mainly as the old one had a pedal that looked like it had an asbestos pad inside it, made of metal and I was dubious on the earthing.
Took the plug off before I tossed the motor...discovered the plug wasn't wired properly...red to live, green to neutral and neutral to earth (showing how old the flex was, flex colours went to brown, blue, green/yellow about 1962 or thereabouts...), would have worked on a non rcd board but of course RCD sees an imbalance between live and neutral and trips...so kept the motor, no idea what I'm going to do with it though...sure I'll find a use...
The colour change for fixed wiring, Ie Twin & Earth was between 2004/6. Flex was way before that,Is that how old the cable with red in it is my grandad gave me a full roll of twin and Earth with those coulers
It's still pretty old I know that because he got it when he was rewiring the houseThe colour change for fixed wiring, Ie Twin & Earth was between 2004/6. Flex was way before that,
flippin eck didnt realise it was that long agoThe colour change for fixed wiring, Ie Twin & Earth was between 2004/6. Flex was way before that,
heres me thinking it was only a couple of years ago
better get that old style cable used up quick![]()
I don't know what you mean... I've never done than...better off keeping if for jobs you'd like to pretend were done years ago... saves getting new stuff inspected/whatever ;-)
Update on strimmer it's up and running still got a little leak but slow enough to have it running and cut the front lawn works very well after a sonic clean of the carb and new pipes it did not need the new pipes but as was apart thought I would renew them I have got a vid but it's to big to post
I used to work right by the villiers estate in Wolverhampton and so many of those engines ended up as scrap when honda engines got put on small gennys and compressors, My dads bench was made from 2 cast iron ends that has the villiers name on, Wish i had them now.3 hour round trip this morning to pick up a couple more Villiers engines.
Mk15 generator set
C30 with unusual vertical tank
