Shedendman
Fix all joints,if you have to put even a slight noggin etc do so,then scrim the joint
Why?lol youve got to take the laths off and the nails
Bodgers always banged the nails in,proper craftsmen de-nail the joistsWhy?
If the boards are screwed to the joists, what effect would leaving the joists in have? It's basically like overboarding an existing ceiling?
Not trying to be argumentative - genuinely want to know!
half inch boards are best in the larger sheetsI'm actually going for 4x3 sheets - less waste, and same joints.
But easier to get in back seat of lexus(shogun is mot-less)
Sorry - I meant laths.Bodgers always banged the nails in,proper craftsmen de-nail the joists![]()
You're not kidding it's completely covered up your usual blue complexion.
Could you remove strips of laths and then staple strips of something strong and thin to support the insulation while you remove the rest of the laths. Then just plasterboard over the top of it all ?There's an inch ofcarpdust and 9inches of insulation being held up by the laths.
I REALLY REALLY REALLY don't want to remove the laths.
Because them horrid laths aren't flat enough,plus at your joints if you screw or nail the board in to much you'll crack the edges split etc,surface flat then board will be flat.But why remove laths?
If boards are going to be screwed to joists?
That's the bit I don't understand...
It wasn't really my choice to take the ceiling down.was there any need to take ceiling down in the first place?
you can just board over the laths as the ceiling is not big enough to overlap the boards enough
i presume thats the landing your doing oh and wait till you plaster that slope as well chuckle
the correct way is de lathe it and de nail the ceiling
I stripped the wallpaper from it, and most of it fell down .
Ok.
I get it now.
STILL don't want to take down the laths, tho.
3x2 CLS framework to screw boards to?
