You should just go for it, think of all the rum you could drink until you get it right
best carried out while on last glass, drill on hammer
Who is it Parm?
I've drilled holes in window glass with a masonry drill & a hand drill, just gone gently & very little pressure, just let the weight of the drill do it.Ok, project now complete and I will post up some pictures latter on
The proprietary glass drill was rubbish, was just skating over the glass.
I used a tipped masory drill 8mm diamter, built a well with blue tac and went very slow cooling the drill bit as I went along. Took a couple of mins
The liquid also absorbs the shock wave created by the drilling & this is why the glass would shatter. See you tube for video of cutting a glass disc with a pair of ordinary scissors. Easily done as long as the glass is submerged in water.Go slow, use a hand drill.
White spirit or meths as a coolant will help.
Build a wall to keep the liquid in. Let the bit do the work.
Use masking tape to mark the spot, drill through until the bit has made a mark, remove tape, build the well and away you go.
