bigegg
- Leeds, West Yorkshire
The wedge only locks one joint.See this is what i thought. And its not even a "pin" as in round pin, that could ware, and get slack, but a wedge that 'pins' into a slot. So ware is taken out, and the wedge will center to the same point again.
But that is in contrast to...
So im still left wondering! : )
You swing the arm by 45degrees, and that puts a side load on the upright pillar which can move it by 1/2 a degree.
That flexes the table, and twists the fence.
The side load moves the yoke slightly.
Then you move it back to 90degrees, to find that everything's out by a millimetre across the 12" cut, so you spend 20 minutes re-squaring it all again.
