boatwayupnorth
To answer your question as to how a more expensive transformer can influence duty cycle, transformer size is not the only variable. Transformer quality (of construction and materials) can determine efficiency, i.e. how much of the input power reaches the output. The difference between input and output power is dissipated as heat. So while a larger transformer will heat up less for a particular power loss, a more efficient transformer will have a smaller power loss to dissipate to start with.
Another variable is open-circuit voltage. I gather that some electrodes are supposed to work best a high-ish OCV. The 6013 rods I bought require, according to the packaging, a minimum 50V OCV. My cheapo arc welder claims 48V OCV, which Im hoping is close enough - just measured it and it ranges from 39V to 46V over the current range. I don't know how this compares with more expensive 160A AC welders and I haven't actually used this particular welder yet.
I hope the really cheapo arc welders aren't total rubbish because I bought one of the Aldi ones a few weeks ago to get back into arc welding. I had a £50 SIP (Weldmate 140?) about 20 years ago from Argos because I could afford neither a MIG (starting price about £500 back then) nor to pay someone to weld my Minis at £10-£15 per hour. I taught myself to weld thin bodywork (Minis, remember?) with an AC arc welder out of necessity. There's no way I would consider that now that I have a MIG (albeit one of the crappier ones).
Then again, I take your point that with the complexity of a MIG compared to an AC arc welder, a cheaply-constructed MIG has the potential to be a lot worse than a cheaply-constructed arc welder. I bought a SIP MIG so I should know...
After all this time I expect to be rubbish with a stick welder so it'll be hard to tell whether it's me or the box. I do wish I hadn't given the SIP 140 away many years ago when I moved house![]()
Hi BillJ and everybody!
I'm new to the forum, standing on the brink of buying my second welder. The first one was many years before one of the cheapo arc welders you were discussing here and neither machine nor operator did meet any standards all then. So, here I am, wondering wether or not to take the chance to buy a MIG. Plans are to use it for building a 40 ft steelboat with the all the weld work surrounding such a project. Welding experience is minimal and professional advice hard to find. I'm living in the far north of Norway were everything costs at least twice as much as anywhere else and the quotes I got for Lincoln, Miller, Esab and Kemppi MIGs put them way out of my reach.
I found some unknown Chinese brands and the much scorned SIP - a SIP Migmate 150 DP to be precise.
I have read the active discussions about SIP migs and also the modifications done on them. All seem to agree that these machines do reasonably well in the beginning and that things go downhill the older the welder gets. So, I would like to ask you and everybody else with a SIP Mig wether or not you think this SIP welder
- would be up to the task of building a single larger project as a 40 ft boat and
- is totally useless in the hands of an unexperienced beginner?
As I said, this is my first message on the forum and English is a foreign language to me. Please bear with me for any technical or linguistical screw up ...
Walter
