brightspark
- yarm stockton on tees
ive got a full pan and tilt black and white camera on my roof its low light and has adjustable 4 to 80mm zoom lenze on it
it dont get better than that and it was free
Eh?Plug into the router same as a laptop would?
I looked at ip cameras but decided against as although the risk is low it would allow aces onto the network unless you put it all on a separate firewall or used a managed router and locked each port to the camera via a mac address.Yes, though if they need PoE (Power over Ethernet), you'd need a PoE injector. Does mean you only have one cable to run to the camera though.
Proper IP cameras will sit on the network as Ethernet devices, often with PoE.
You say they run on the house ethernet - do you mean they just use the CAT 5 cables or do they connect the actual PC network via the router?
didn't show u his id and say he was a reformed criminal and got a job as an apprentice did he then tried flogging u some crap gear he got from the pound shop for a tenner ??I have four Amcrest 1080P POE cameras.They connect to a POE switch in the shed which connects to the router via a homeplug. Software is Synology Surveillance Station running on a Synology NAS. The NAS periodically uploads to a cloud server since canny burglars have been known to steal the computers and PDRs if they spot your cameras.
Here's a pic of a Nottingham Knocker who called recently.
As you are here you probably realise how useful forums are, try https://ipcamtalk.com/
Once you spend some time there you will simply buy Dahua 2MP cameras from empire on Aliexpress and get a PC from eBay to run Blue Iris software I expect, seems the most common route.
As most have already said, don't even consider wireless. Use IP cameras and a PoE supply. I use stand alone PoE switchs, if the power supply fails it's easier and faster to swap out and cheaper than integrated PoE supply to do so.
Dahua make a lot of the bundles you see for sale, Swann etc but they are the low grade cameras generally, the range they make is huge, the starlight versions are generally the recommended type.
Do not get caught up in more MP, more better, line of thought. The 2MP cameras are significantly better than even the 12MP (4K) in anything but glorious sunshine. Most instances you really need to see CCTV images tend to be at night.
Some people run a setup like RDR, lots of Hikvision fans and NVR fans but generally outnumbered, or at least out shouted by the Dahua and Blue Iris crowd on that forum.
there ok. not numberplate quality and need general lighting to be of any good not just the ir on them![]()
