Wheely
New Member
- Accra- Ghana
Hi guys,
I am stripping down my Defender to prep it for my Africa Overland.
I am down to 3 options:
-Hot-Dip Galvanising
-Zinga (Cold Galvanising method): Zinga is an active zinc performance coating which works in conjunction with the metal beneath whereas paints are only passive barriers. Regardless of how thick paints are applied, they remain as barriers. Once they are breached corrosion sets in immediately. If the Zinga layer is sufficiently damaged to expose the base metal below, the steel would form a layer of surface rust but no corrosion would take place beneath it.
-External Coating paint Epoxy Mastic 121: (winner of the Winner of the Classics monthly 3 year test http://www.rust.co.uk/filestore/3 YEAR TEST SUMMARY PDF.pdf) Epoxy Mastic is a two component Epoxy paint composed of nanoscale corrosion protective pigments in short chain molecules with very low surface tension. This allows the paint to flow into all of the pits and troughs on the steel's surface, ensuring a tough penetrating primary bond. This is the best kind of bond you can get with a paint finish.The high build epoxy forms a super strong protective barrier over the corrosion inhibiting pigments that hug the steels surface Excellent penetration and adhesion within a high build coating equals exceptional mechanical strength.
What are the pro's and con's of each of the 3 alternatives? what would you guys choose and why?
Thanks,
Simone
Thanks,
Simone
