Pete.
- Kent, UK
Here's a trick I learned from John Stevenson a while ago. 3 phase coolant pumps are quite happy to run on single phase using the same principle as rotary converters. All you have to do is wire a small capacitor like the ones you find in the old strip lights to the third phase and it'll work just fine. To demonstrate, I quickly lashed-up a small pump I have here with a 10uF 250v capacitor. My pump here is dual-voltage but I am pretty sure it would work just as well if it were 415v only. They don't use a lot of power and there's no starting load.
Anyway, here's the vid of it starting and running.
3 phase suds pump on single phase with capacitor
well, if yesterday is anything to go by,and it did go by so it must be, but if it was tomorrow that would make it thursday wouldnt it
and as you are in earth dimension C ,it might even be the day after. I would check before going out just in case you are already out. was it 230 or 415 ?
. I'm not sure how hot they can get before damaging the windings.
