8ob
- Nescient in the vale
Yes but if you do that it then has to work but is not needed legally![]()
You are right Norm, sod the brakes
What's the problem here ?You are right Norm, sod the brakes
ab![]()
I beg to differ, as I have a trailer that has drum brakes and that only works as a handbrake, there is no possible way for it as built to work as a service brake, so does that mean it falls into the un-braked i.e. sub 750kg category of trailers then ?
It's not homemade, it was produced in volume by a big manufacturer but it is rather old...
they do work fully, as they where designed to park the trailer only they where never intended to be used as service brakes and are not required under 20mph anyway.You can differ all you like.
The law is clear.
If fitted they must work fully.
They do work fully, it's just they were never designed to be a service brake only ever as a parking brake.If fitted they must work fully.
Yes read the regs aboveSo I'll repeat my question... is it legal to tow said trailer on the road and if so is it effectively classed as un-braked and therefore sub 750kg ?
although this is a model of a massey 3ton ( I do realise), it gives the basics of how the hand brake is applied whilst on the tractor and the pick up hitch and how the brakes could never work as service brakes unless modified to fit a hydraulic ram as mentioned ,You can differ all you like.
The law is clear.
The biggest problem with tiny trailers is not being able to see them in your mirrors - it makes it difficult to judge where they are and where they're going. Also the short length makes them twitchy going backwards.
I've got a small trailer that's about the same size as those ones from halfords (although it was made in Germany in the 60s) and I can reverse with it, but it's not much fun sometimes.
t
as amatter of fact was looking at a massy 3 tonner the other day local farmer had bought one from ireland
edit found one
The way the brake works is you stop, with the tractor brakes physically turn round apply the handbrake from the tractor seat, then drop the pickup hitch and the trailer is left with the handbrake on, to save it rolling away on the field etcthen the opposite when hitching up, it would be fun trying to apply that lever whilst driving
most arms have been ripped off or rotted away now, and most farmers use a hand-BRICK with them.
like to see ya do it, you would need long armsManualy by the driver from his seat.
so you can see the trailer i used to use a length of garden cane with a bit of rag or a flag on it so you could see the stumpy trailer
No agri stuff is rated on payload so 3ton is 3ton load 4ton is 4ton load, reasoning is how is a farm labourer supposed to know the weight of the trailer? if its 4 ton he puts 80 bags of tatties in, easy. ---- meat ----make it easy tayterfound one here seem is was a four ton trailer so 3 ton load i presume
If ya dont use em, you soon loose the knack-as you used to have.I lose the knack
its a 3ton payload so approx 750 net weight so gross 3750 kg ishSub 750kg? No how can it be? Or it would be over loaded.
SWMBO is a horseist and part of what she does is schooling, we get about ten nag trailers a day pull into here and invariably they cant turn them around which is ridiculous because its the same space we turn the artic around in. Irrespective of the space given on the test I believe the training is a good thing. If I have the time ( meaning if they are totty) I spend a few moments with them and its amazing the difference a few pointers can make to their reversing skills.
Bob
Out of farmers, building/mini digger/plant people, horsey folk and caravanners it is the latter which really need training as there must be a heck of a lot more incompetent and dangerous caravan owners on the road than anyone else with trailers put together.
