cant go wrong with blue rolls Royce use itHi
I am needing some gasket sealant. I was just going to go for the normal stuff I use hylomar blue. I was wondering people's views and if there is anything better or just stick with that?
Regards
so do IExactly. Seeing it in an oil pump strainer certainly puts you off the stuff.whats it for and did the factory use sealant? ...i hate seeing huge gobs of blue silicone squeezed out of gaskets , often finds its way into the oil strainer
Just don't get well seal on your hands.....With clean flat faces & a paper, gasket grease is all you should need.
Years ago I stripped a BDA that had ran a big end then put the rod through the block.
The pickup pipe gauze was blocked with Hylomar.
For face, to face alloy either good grade, RTV or a sealant called "Well Seal"
We used to call the bright orange RTV fools gold lol
Hi
Yes it's at transfer box. It's a 76 series 3
Been a lifelong proponent of Hylomar Blue. The mistake most people make with it is put too much on and it squidges out, only a smear is needed.Hi
Regards
